Bare minimum to run
Old Feb 18, 2020 | 12:38 AM
Dr1rrrr's Avatar
Default Bare minimum to run
Hello I have a S10 I am swapping a 4.8L truck engine into. It has a factory harness and factory fuse box and I want to know what are the bare minimum wires that need to be hooked up to make the engine run. I don't want to thin out the harness yet. I just to Leave it as is and get it started.
Old Feb 18, 2020 | 07:52 AM
1964SS's Avatar
http://lt1swap.com/wiringharness.htm
Old Feb 18, 2020 | 10:15 AM
ryeguy2006a's Avatar
That's a really wide open question there. I'm going to assume you have the proper fuel, exhaust, engine mounts, air intake and etc and that you are only questioning the wiring aspect. First of all to run more than about 3 seconds, you'll need to have the VATS deleted, so you'll need to send the ECU out or find a buddy with HP Tuners. Next would be using the link above to basically tie all pink wires to ignition 12v, Orange wires to constant 12v, and black wires to ground. You'll need to either manually turn on a fuel pump or rig up the fuel pump output to a relay to turn on the fuel pump.
Old Feb 22, 2020 | 11:24 AM
jz2518's Avatar
Watch the last video of lt1swap on YouTube to make the fuse box. And use ls android to remove vats. Fuse box about $5 on Amazon and $50 for obdlink. You can keep the harness intact. No need to thin it out. Keep it simple
