05 Express van donor???
Old Mar 5, 2020 | 10:32 PM
Murray's Avatar
Default 05 Express van donor???
I have a possible line on an insurance 05 Express van 3500 with 6.0 / 4L80E. It was a team transport van with 170,000 mostly highway miles. If I can get it cheap enough it might make a good donor motor BUT I've never pulled a motor from a van before. What kind of difficulties might I be looking at?
Old Mar 5, 2020 | 10:52 PM
LLLosingit's Avatar
If it's going to the crusher afterward just use a Sawzall and some good blades, Unbolt the grille assembly or cut it out and cut sway part of the cowl and it will come right out complete(motor and trans). If you don't cut the cowl then pull the intake. I pulled the motor and trans in about an hour saving the wires harness but cutting anything else in the way.
Old Mar 7, 2020 | 12:42 PM
CutLS's Avatar
Unless you have a hoist to lift the body off the frame, you need to removed the grille, condenser, and radiator. You should be able to pull it out the front. Might be easier to pull the engine by itself but you probably would be able to do both.
