DBC to DBW conversion
Old Mar 7, 2020 | 11:47 PM
charlie6178's Avatar
Default DBC to DBW conversion
I have a PSI conversions harness for my 2000 LS1 in my nova, and I have it set up DBC right now, with the 0411 PCM, and I want to switch it to DBW instead. Main reason is I am looking to do the DeLS3 style intake setup with the look of an old carb. Will I need to swap for a DBW harness? Or is there a conversion kit available??
Old Mar 8, 2020 | 08:38 AM
1964SS's Avatar
Is your pcm a 2000 as well? Red blue pcm will not accommodate dbw. You will need a 2003 or newer green blue pcm. Not sure about a conversion harness. You will probably have to add the needed wires and repin them.
Old Mar 8, 2020 | 08:49 AM
ls1nova71's Avatar
The red/blue PCM will work with DBW, but you will have to use a corvette TB and TAC module, which are a lot more expensive than the other ones. Then reflash to a 2000 corvette tune and rewire like a corvette too. Or you could probably use 2001-2 truck dbw stuff and flash it like a truck and modify the tune for the larger displacement of your LS1. The truck stuff is easier to find and a lot cheaper.
Old Mar 8, 2020 | 11:02 AM
I believe mine is red / blue. So it might be better to just spend another $550 on another harness then
Old Mar 9, 2020 | 07:50 AM
ryeguy2006a's Avatar
Or you could run a Terminator X Max
