Low pressure oil light location
Summit sells the warning sensor and everything needed an i think I found a fitting for the sensor that goes to an LS on eBay.
thanks !
The plug at the front of the engine is shown here -- I used it to prime the oil system before start up.
Attachment 714174
The plug at the back of the engine is shown here -- you can see the oil temp sensor with wire attached; just below it is the cross bolt for the main bearing cap.
Attachment 714175
the drivers side of my engine is extremely tight. I might be able to get to the front plug where Michael posted a picture of. But no where else on the drivers side.
