Stopped up injectors
Old Mar 10, 2020 | 07:57 PM
showdog75's Avatar
Default Stopped up injectors
I've got a ls2 that's sat for nearly 5 years and until recently did I realize that it still had gas in the fuel rail. Obviously it was very stale. What's the chance that all 8 injectors are gummed up to the point it won't begin to try and fire? I did check for spark and all injector plugs have fire according to a noid light. Tomorrow I'm going to check and make sure that it's actually pumping fuel and check the pressure at the rail. I can't get to involved at the moment as I've got a work project coming up. I would love to hear this thing act like it wants to fire up.
Old Mar 10, 2020 | 08:13 PM
Old Geezer's Avatar
I just finished cleaning and flow testing a set of injs, that had been sitting for??
2 of the 8 were locked up. All 8 had rotten, stinkin gas in them.
I ran them thru the ultrasonic cleaner, for 4- 20 min cycles. The cleaner was heated to 110*.
Worked perfectly. All 8 are "dead-on" for flow and pattern.
I suggest you not try to start the engine until you have dumped the rotten fuel. You may be able to use some Seafoam, and a 9V batt to see if they are locked up.
Real way to do it, is to have them cleaned and flow tested, all new wear items installed.
Old Mar 10, 2020 | 08:22 PM
showdog75's Avatar
Where in Georgia are you located?
Old Mar 10, 2020 | 08:26 PM
cdk4219's Avatar
I had one air for 10 years and all 8 were totally stopped. Wouldn’t even cough when started, not sure about 5 years
Old Mar 10, 2020 | 09:04 PM
68Formula's Avatar
They likely could be sticky, but otherwise they should be okay. Just have to get them loose.
Turn them upside down and give them a vigorous shake. Pre-fill each with fuel, install in the fuel rail and hook up the injectors to the wire harness. Instead of installing into the intake, put the assembly on top of a pan (or cookie sheet - but don't use it to cook after ). Put sheets of paper between the pan the injector tips. With the fuel pump off (so it doesn't build pressure), let the engine crank for a few seconds. Check for wetting on the paper under each injector.
Old Mar 11, 2020 | 06:59 AM
Old Geezer's Avatar
Default Location....
East of Atlanta, about 10 mi north of I-20, exit 114.
Old Mar 11, 2020 | 09:52 AM
Haggar's Avatar
I just went through this last year. I wanted to swap my TBSS LS2 manifold and injectors onto my LQ4. Had been sitting for 5 years. There was still a lot of gas in the rail, nasty varnish smelling.
I used a 9v to check them, 4 were stuck. I never tried to unstick them, as I had a 2nd set of LS2 injectors already in the truck. It just would have made my life easier if those had worked.
Old Mar 11, 2020 | 12:55 PM
showdog75's Avatar
Found a local guy that sonic cleans and flow test for $15 a injector.
 Michael S. Palmer
Old Mar 12, 2020 | 08:09 AM
SE-R Spec's Avatar
Change the fuel filter before start up as well. I’ve had the filter element disintegrate and clog the injectors after a vehicle has sat for a long period of time
Derek
Old Mar 12, 2020 | 08:14 AM
showdog75's Avatar
Derek
Fuel filter,pump, and the tank are all new never used.
Old Mar 20, 2020 | 07:38 PM
Alwhite00's Avatar
Soaked some in acetone to break em’ loose before. Worked good.
Old Mar 22, 2020 | 11:23 AM
Jimbo1367's Avatar
I've never heard of this method before. Does anyone know for sure if the acetone reacts to the o-rings? I've only used Seafoam (worked great FTW)
