Nv3500 4x4 to a 4.8 ls I need help finding the right flywheel and whatever other parts to put an nv3500 in my truck I swapped a 4.8 4l60e I to an 87 square body a few months ago and want to put the nv3500 in it any help with part numbers and advice would be greatly appreciated thanks in advance. |
Wasn't the NV3500 a factory option behind the 4.8 in the early 2000s? Why not just get the OEM parts? |
Yes they was they had a internal slave cylinder mine is external dont know if that matters and I was also told the back of the crank might be different this is why I'm asking. |
The 1999-2000 LR4 4.8L engines built for manual transmission usage were equipped with a longer crankshaft than the engines used for automatic transmission applications. |
Do you know who would offer a spacer to make the automatic crank same length as standard? |
Look here, this will show you the long and short style. Both were used with NV3500s in OEM applications https://www.novak-adapt.com/knowledge/gm-crank-spacing/ |
Originally Posted by brianthompsonsmith
(Post 20221146)
There is some good information in the link to the Novak site regarding clutch contact surface area on the flywheel that warrants reading to keep you from ending up with an inadequate clutch/flywheel combination. |
Can you send me that link please and thank you? |
(Post 20221198)
i put a nv3500 behind my 99 4.8 in my 94 k2500. i used the sachs flywheel nfw1050, 6302vsp43 napa pilot bearing stock 94 clutch drilled out 3 holes to fit the 10mm bolts jegs 555-601015 flywheel bolts arp 134-2203 pressure plate bolts the stock external slave cylinder from the 94 truck worked fine. |
Did you need to put a crank spacer in and was your 4.8 originally automatic of 5 speed? |
no crank spacer needed for me. the pilot bearing makes up the difference. i believe it is .400" wider if i remember right. my 4.8 was originally mated to a 4l60e automatic. |
That is what my setup is right now so that list of parts you give me should work thanks again I really appreciate your help. |
Originally Posted by jeffs55chevy
(Post 20223222)
I’m using the stock truck oil pan from the 4wd 99 Sierra. The slave cylinder even clears the low oil sensor in the pan. The slave cylinder I’m using is a 90-91 Chevy truck style because it takes a normal inverted flare line instead of the roll pin setup. So maybe that is shorter than the 94 style slave cylinder. https://cimg3.ibsrv.net/gimg/ls1tech...ae7bf413b.jpeg |
(Post 20224464)
No problem. Now that I think of it, it might have been a metric bubble flare and not inverted, but either way it’s an easier setup than the roll pin style especially if you have to make your own line. |
© 2024 MH Sub I, LLC dba Internet Brands
