Wiring an electronic speedo
I am putting a classic instruments guage into my 57 Chev truck. Installed a 01 4.8 w a 4L60E and a FITech ultimate LS w/trans controller.
I am no wiring genius and am stumped on one issue.
The electronic speedo has to be connected to the VSS The gauge instruction says:
( b. One (either) wire of an electronic transmission 2-wire vehicle speed sensor [VSS]. i. Connect the other wire of the VSS to the same point as the wire harness Black ground wire.)
Do I disconnect the wire from the FITech wiring harness or do I just tap into these wires. (two wire )
