Block Plug removal ?
Old Apr 6, 2020 | 01:47 PM
tmcmillan5's Avatar
Default Block Plug removal ?
Trying to remove the 17mm allen hex block plug so I can tap for a mechanical temp sender but the plug does not seem to want to come out to easily. I don't want to break anything so are there any good tricks for removal ? The engine is in the car and I have used a 1/2" breaker bar and an electric 1/2" impact on it to no avail.
Thanks, Tony
Old Apr 8, 2020 | 05:49 PM
1FastBrick's Avatar
Try heating up the surface around the plug. might help break the bond. They are tight!
They have sealant and a metal o-ring on them. I believe they get torqued to 44Lb too...
