Power steering pump issue
Old Apr 17, 2020 | 06:44 PM
Stickmano's Avatar
Default Power steering pump issue
68 camaro. Have a Holley 20-185P ls accessory drive kit. Kit came with Holley 198-101 power steering pump. However, I'm running hydroboost brakes and the pump only has 1 return port. Pump is a gm type 2 or saganaw TC series. Any advise on what type of pump will work? Pump sits driver's side low and has a .667 shaft diameter. Would rather have reservoir attached to pump. Thanks
Old Apr 17, 2020 | 06:49 PM
2knight's Avatar
I did a hydroboost swap on older truck and I can tell you in my experience anyways that the single return port works flawlessly. I used a brass pex tee and connected brakes so it was straight through the T and power steering return went through cooler 1st then into the 90 part of T.
Old Apr 17, 2020 | 06:53 PM
Stickmano's Avatar
Not running a cooler but I thought about trying that.
Old Apr 17, 2020 | 07:00 PM
Stickmano's Avatar
Default Power stering pump ls3
Old Apr 17, 2020 | 07:06 PM
2knight's Avatar
With the hydroboost adding more heat and not wanting my brakes to suffer I figured it was worth it. I just picked up a small one from junkyard for few bucks. Maybe 8x3 in size. But no issues and I love the hydroboost so much I want it in every vehicle I drive!
