Drive by wire v6 pedal???
Old May 9, 2020 | 11:26 AM
GHall8788's Avatar
Default Drive by wire v6 pedal???
Good morning, I’m in the middle of piecing my build together (2002 camaro) and I’m at point where I need my new ecu and throttle body. Terminator x vs x max and DBW vs DBC. The only thing I have no figured out is the pedal assembly. I see the v6 cars have dbw pedals, but I can’t find if anyone has used them in the v8s. I would imagine they bolt in. Or any other pedal someone has gotten to fit. Any help would be great. Thanks in advance.
Old May 9, 2020 | 04:38 PM
NCDEERE's Avatar
Holley has a list of compatible pedals on their site. I seem to remember that some of the V6 pedals are compatible. Search the GM pedal numbers from Holley on Oreillys site and then look at the vehicles they fit.
Old May 9, 2020 | 08:41 PM
LS BRAVADA's Avatar
My V6 APP worked perfectly on my V8 swap
Old May 10, 2020 | 02:22 AM
GHall8788's Avatar
Was your swap worth it over cable? And what car do you have? Trying to see if the v6 pedal will just bolt into the v8 or does there need to be fabrication?
Old May 10, 2020 | 06:34 AM
LS BRAVADA's Avatar
2008 Cadillac CTS
Old May 10, 2020 | 12:00 PM
Project GatTagO's Avatar
The 4th gen v8 F-bodies never had DBW. The Terminator X Max system recommends this pedal 10379038. I can also tell you that from experience, other pedals will work, but are not officially supported by Holley.
Andrew
Old May 10, 2020 | 10:54 PM
GHall8788's Avatar
yeah I knew the v8s didn’t which I why I was trying the v6. I’ll check that pedal out thanks for the help! If I do go DBW then I’ll post if I make a bracket
Andrew
