i need help installing painless LS1 harness
Ryan
The gear shift indicator isn't going to work unless you keep the 4.3 computer.
Basicly, the Painless LS1 harness is deffinately not what you should have picked if you wanted everything to function properly after the swap.
The computer needs to know when you hit the brakes so it can unlock the torque converter. That is the need for the brake wire (Yes, the purple wire, Pin E in that connector I mentioned)
The other wire you are talking about tells the computer when you are out of Park or Neutral and in a drive gear, it does this using Ground when the vehicle is in Park or Neutral, and is just open when it is in drive. On your blazer, this wire would be in the larger of the 2 connectors (gray connector) that go to the switch on the drivers side of the transmission. Pin A supplies the signal you need.
The Park Neutral wire would be C1 on the Park Neutral Switch, Pin A.
Try these sites...
http://s10forum.com/forum/forumdisplay.php?f=10
http://s-seriesforum.com/forum/forumdisplay.php?f=16
and http://currentperformance.com
