1969 Suburban
Old Jun 21, 2020 | 01:28 AM
Twin_Turbo's Avatar
Default 1969 Suburban
Swapping a fresh ls1 into 69 suburban. Fits like a glove. Using ls3 manifolds (they sure are pretty identical to the hooker blackhearts) they will get a black coat. The engine paint (ral 7042) will also go on the outside of the car (roof and pillars)
Attached Thumbnails 1969 Suburban-20200620_134246.jpg   1969 Suburban-20200620_134346.jpg   1969 Suburban-20200620_123501.jpg   1969 Suburban-20200620_151457.jpg   1969 Suburban-20200620_152023.jpg
Old Jun 21, 2020 | 09:00 AM
Jimbo1367's Avatar
Looks nice. Any more pics?
Old Jun 21, 2020 | 12:04 PM
Twin_Turbo's Avatar
Sure hope this works
https://photos.app.goo.gl/1HfFiwLcpgiMsJ3p7
Old Jul 11, 2020 | 07:50 AM
Twin_Turbo's Avatar
Slow progress. I made the original pedal work using a truck cable a few leftovers from a lokar set and a hose clamp. I filed a deeper slot in the lokar end to allow swiveling. A small slot to loop the cable back so a hose clamp retains the looped back cable. Works like a charm
Attached Thumbnails 1969 Suburban-20200711_144601.jpg   1969 Suburban-20200711_143613.jpg   1969 Suburban-20200711_143619.jpg
Old Jul 11, 2020 | 07:58 AM
Twin_Turbo's Avatar
Radiator made to fit. Power steering hoses fit after modifying. I like to use oem stuff if I can.
Attached Thumbnails 1969 Suburban-1594472041211.jpg   1969 Suburban-1594472059455.jpg   1969 Suburban-1594472081821.jpg
Old Jul 11, 2020 | 03:58 PM
Project GatTagO's Avatar
Cool build! I always liked the older Suburbans.
The Hooker manifolds are actually quite different, but they do use the same outlet flange. Your manifolds kick out quite a bit at the exit and the outlet points down. The Holley manifolds tuck tightly to the block and the outlet points back and down at about a 45 degree angle. They also don't have the bosses for the head shields.
Andrew
Old Jul 11, 2020 | 04:31 PM
Twin_Turbo's Avatar
I know about the shields...but these fit fine. And i had them lying around. Parts are super exoensive to ship to NL. Gotta work with whats best whilst kerping an eye on the bank book.
Old Jul 11, 2020 | 06:20 PM
Fair enough...I just don't want people to think that the Hooker manifolds are the same as the LS3 Camaro manifolds, because they are not. It's great that they worked for you, but they would never fit in my Cougar.
Andrew
