Rebuild/conversion v6>v8 camaro
Because it's a 5.7 I'm planning to swap over all the suspension and brake parts, the rear end, drive shaft, interior, cooling system, exhaust etc. Essentially I'll be doing a full restoration/conversion.
I think I can handle each part individually with a little help, but the problem is... I don't know where to start... what order should i replace stuff?
The Haynes manual is all about "lower this to get to that" and "remove A to get to B".
Is there any sequency of installation that would reduce time spent putting stuff on, then taking it back off to put something else on?
Thanks,
