Using a factory pcm igntion system for a carburator?
heres a tps kit
https://www.holley.com/products/fuel.../parts/534-202
I'm a fuel injection guy through and through - however I understand there is a place for carbs and I still do stuff with them. Carbs aren't simpler than fuel injection we've just had them for the last 150+ years and they are better understood by a larger section of the population.
What I don't understand is how / why you feel using the factory equipment that came with the engine is too expensive. If you feel it's too complicated, won't look right on your setup, can't tune it yourself and don't have anyone you can trust or don't feel comfortable with wiring, etc. I get it - this happens for people so they default to what they know. I read your post within an hour of its creation and I simply don't understand the logic of trying to run a computer controlled transmission with the factory ECM and control the fueling with a carburetor. I'm not saying it can't be done (I'm rarely that guy) but within the OEM ECM much of the shift points and shift firmness depend on engine load, throttle position, vehicle speed and RPM. Without having some sort of feedback from the engine I simply don't see it working or if it does, not very well.
I'm not trying to be negative but why not cut the baloney and simply purchase an aftermarket transmission controller for your application and call it done. They are designed to be stand alone and don't rely on so many parameters for shifting and shift quality. I realize this may be a few hundred dollars or more including harness but a couple wires and a few plugs later and the job is DONE and you're driving instead of troubleshooting your creation. That is always a happy day for me.
In the end this is your project so build however you feel will make you happy but don't be surprised when people are offering less than enthusiastic support for what sounds like a Rube Goldberg idea.
$270.00
holley terminator x
$1080.00
Total-$1350.00
carb setup
Holley intake 300-130 at summit with studs $338.98
Msd6014-$412.25
mallory pressure regulator $150.00
demon carb- $335.00
Air cleaner 50.00
total-$1285.25
So whats your point exactly
all brand new carb related items came out cheaper
you dont know what I need my build to do carbs have been around longer than efi has think it's easier to buy an old carb guy a 6 pack and pack of cigarettes to tune a carb over paying big money for computer tuning and dyno time, look analog is better for me cause I can learn it and trust me when I say this that thousands of others dont wanna sit there and learn fuel tables when you can just turn a screw driver and get on the road simplicity by the way I have both a carb and the terminator x ironically the cars been on the road longer with a carb than any efi I had on my car like I said it works for me and it's an option for many others also the terminator x is for sale because again I DONT NEED EFI
$270.00
holley terminator x
$1080.00
Total-$1350.00
carb setup
Msd6014-$412.25
demon carb- $335.00
Air cleaner 50.00
total-$1285.25
and prove your point? I didnt ,had a carb setup been 600 total than id proudly take the "cheap ***" jab with pride and again if you dont wanna adjust things on your car then dont have a project car like I said I dont mind adjusting a carb i really dont and that's why you dont put all your eggs in one basket if your ls swap isnt your only car than the adjustments shouldn't be a problem that's why I have a little rice rocket daily it's a FUEL INJECTED 4 cylinder and lol did you really bring up gas milage? besides its allways hot in TX so the "constant" need of adjustment for temperature isnt a factor here lmao as a matter of fact a carb with no choke around here wouldn't be a problem like I said I know the majority of people prefer efi trust me I've tried both gm computer and the holley because I was going turbo but I ran out of budget and running a near stock NA 5.3 with a really nice efi system like this didnt make sense so I threw the carb back on it and am selling the terminator x because I have no need for it seriously efi is preferred by almost anyone but dont discourage others, i feel kinda of bad for the other carb guys people bully them into getting rid of there carb setups and all that happens is that their cars are just parked outside because they gotta learn how to adjust fuel tables seriously anyone wanting to run a carb and your reading this DO IT because your the one that's gonna be working on your car not the guys on here that keep trying to shove efi down everyone's throat 👌
Fuel mileage is one of the huge benefits to running an LS motor, so if you are discounting that you are missing out on one of the biggest advantages to these motors. Just because cars from the 60s, 70s, and 80's only got 10-12 mpg doesn't mean that you should tune your LS motor to get that type of mileage. I'd rather use my fuel savings to save up and buy a cam, go fast parts or deluxe screwdriver sets than running it out the tail pipe.
