PNP Switch for Connect and Drive
Old Aug 13, 2020 | 09:59 AM
Zorglub123's Avatar
Default PNP Switch for Connect and Drive
I’m finishing the install of a “connect and drive” LS3 and I’m lost with regards to the Park/Neutral Position switch (PNP). The switch is installed on the 4L70E gearbox, but there are no connectors on either the Supermatic pigtail or the engine ECU to connect to it. From what I can see on the Connect and Cruise wiring diagram, this switch does not exist!
I understand the 7 way connector will give some signals such as backup lamp and neutral safety switch. The second 4 way connector gives a transmission range signal.
Question: I only see a use for the backup lamp, given that all the other controls should be handled by the GMPP ECU or the Supermatic box. Am I wrong? Any advise to where I should connect this switch?
Thanks
Old Aug 13, 2020 | 10:27 AM
bobcratch's Avatar
Thanks
typically its used as the ground for a starter relay coil.
Old Aug 14, 2020 | 02:22 AM
Zorglub123's Avatar
I dont think that’s the case for the crate GMPP engine. Any other ideas? Thanks
Old Aug 14, 2020 | 05:14 AM
bobcratch's Avatar
it does not have to be used for anything. The engine controller probably doesn't look at it or care about it. It is mainly used to prevent the vehicle from being started in gear, which is why many use it as the ground for the starter relay. Same goes for the backup lamps. Only used for backup lamps, the engine controller does not care about that signal.
in my swap i do not have or use a PNP switch and it works fine. However, the car can be started in gear, which is not ideal.
Old Aug 14, 2020 | 06:47 AM
Zorglub123's Avatar
Thanks Bobcratch, that was my initial thought but i wanted to be sure. Weird that GMPP does not address this in the documentation...
Old Aug 14, 2020 | 09:37 AM
Project GatTagO's Avatar
They don't address it because it is part of the vehicle wiring, not the ECU/trans wiring.
Andrew
