presentation
Old Sep 10, 2020 | 08:45 AM
Rodolfo's Avatar
Default presentation
Good morning thanks for accepting me .. let me tell you I have a Camaro ls3 engine with its ecu and I need to know the input pins of the 2012 Camaro dashboard to be able to connect it to the ecu ..
Old Sep 10, 2020 | 03:04 PM
kipps's Avatar
You can't directly connect the instrument cluster to the ECM(engine control module).
The ECM communicates with the BCM(body control module) with a CAN bus link. The BCM communicates with the IPC(Instrument Panel Cluster), via a different CAN bus link. The IPC decodes the information from the BCM, and operates it's gauges and lights accordingly.
AllDataDiy is the place to go for "theory of operation" and pinouts for these vehicles.
Old Sep 10, 2020 | 05:33 PM
Rodolfo's Avatar
thank you very much for the information ... practically impossible to make go ..
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
