dipsticks
Old Sep 14, 2020 | 10:57 AM
Chris Tough's Avatar
Default dipsticks
do all block mounted dipsticks have the level marks in the same place? I ask because I have a 4.8 with a chopped truck oil pan in my fairmont but I'm using an ls1 f body dipstick and im worried my level maybe incorrect. cheers
Old Sep 14, 2020 | 12:31 PM
Only way to ascertain that is to drain the pan, then refill it with the proper amount of oil.
Then put the dipstick in and see where the oil sits on the dipstick. Then you will know.
Old Sep 14, 2020 | 06:01 PM
Project GatTagO's Avatar
Originally Posted by Chris Tough
do all block mounted dipsticks have the level marks in the same place? ...
Yes. As long as you don't mix and match different dipsticks with different tubes, you are fine.
Andrew
