LS help transmission and controller/harness 08ly6
Old Sep 22, 2020 | 10:55 PM
ss67's Avatar
Default LS help transmission and controller/harness 08ly6
im doing a 08 ly6 swap in a old buick the 6l90 thats with it is way to big.was recommended to run a 4l60 from like 2000-2005 the problem is all the aftermarket plug and play controller and harnesses state 2007 and newer 4l60.was looking into holley terminator max X it states 2007 newer 4l60 to.im trying to do as affordable as i can.i found a 04 4l60 way cheaper than a 2007 4l60 .what do you LS swap guys recommend for transmission and year to use behind the 08 ly6 dbw and what aftermarket plug and play ecm,tcm,harness kit is best..looking for the easiest setup to get it on the road it is just going to be a cruiser not a race car.thank you for your time
