1986 C10 LS3 swap
I'm looking at 86 C10 LS3/4L60E swap. Haven't purchased the truck yet just doing some research.
1. What motor mounts would you use with Speed Engineering headers? I have the Speed Engineering headers on my 68 C10 LS swap and they work well.
2. What kit to adapt the stock 86 C10 steering column linkage to the 4L60E?
3. Oil pan. Currently I have an 2002 fbody pan on the LS3. Will it work on the 86?
4. Truck has AC. I'm considering keeping the stock AC. Or maybe aftermarket AC. Pros and cons of either?
Thanks
Personally, I'm using a set of Ebay mounts that mount the LS truck engine in the same exact location as the old small block. I'm installing this in a 4wd k20, so I had to cut a small notch in the engine crossmember to clear the oil pan. I also am not running AC, so no problem there. The reason for choosing these mounts was so I wouldn't have to change both driveshafts and modify the shift linkage for the transfer case.
