Alternator Wiring Question
Old Oct 13, 2020 | 09:35 PM
Jonathan McGilvrey's Avatar
Default Alternator Wiring Question
Hey guys,
I'm trying to get this project driving, but I'm not sure how to get the alternator to charge. The swap is uses a 2015 Camaro SS ecm and the alternator is a new high output NAPA unit that came out of a 2004 Cadillac Escalade, I don't know what type of signal to which pin to send the alternator so itll start charging and I couldn't find anything definitive when I searched.
Old Oct 14, 2020 | 09:57 PM
LLLosingit's Avatar
Originally Posted by Jonathan McGilvrey
Hey guys,
You might have better luck trying a local alternator rebuilder if you have one, I have one near me that has been in business for decades and the owner pretty much knows everything there is to know. I know on my s10 swap I only had to wire in a dummy light to get the alternator excited, Other people use a resistor and neither uses ecu input. What is it going into?
Old Oct 15, 2020 | 05:03 PM
Project GatTagO's Avatar
Hey guys,
Holley 197-400. The wire already has the resistor built in and should be connected to switched power. I would also add a terminal to the S cavity and wire it to a point in the electrical system that experiences the most current draw, in other words, the main power distribution point.
Andrew
Old Oct 19, 2020 | 08:14 AM
130fe's Avatar
Andrew, what does adding the extra pin do (system operation)?
Old Oct 19, 2020 | 08:35 AM
It tells the alternator when there is a heavy load in the system and boosts output, which tends to keep voltage more consistent.
Andrew
