V6 /LS1 swap tip
Old Jul 18, 2004 | 05:08 PM
badjuju342's Avatar
Deranged Rat Fink
Default V6 /LS1 swap tip
one of the guys in my car club swapped an LS1 into a '98 V6 camaro. everything looked the same but he ran across a snag: the steering shaft coupler was too short to reach the rack& pinion . looked up the P/N for a replacement rack , it stated was the same ,it ISN"T. I still had the rack on the K-member from the LS1/T56 i bought for my vert and we did a comparision with his V6 rack , the angle is different on the steering shaft and the shaft on the LS1 rack is about an inch closer to the left side than the center. this might help some of you guys keep from tearing your hair out trying to figure out what you did wrong , you didn't . hope this helps.
Old Jul 19, 2004 | 09:18 AM
badjuju342's Avatar
Deranged Rat Fink
here's a pic, the top one is the LS1, bottom is a V6
Attached Thumbnails V6 /LS1 swap tip-dscf0290.jpg
Old Jul 22, 2004 | 11:57 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Magnus did a swap into a 97 Firebird last year and he's running a LS1 rack and steering linkage.
Old Jul 22, 2004 | 12:22 PM
badjuju342's Avatar
Deranged Rat Fink
this particular car was a '98 Camaro, the steering column would not bolt up , no way , no how. he is using headers also so that may have been a factor. just thought it might help save somebody so headaches.
