LS2 wiring harness repair / replace
Old Oct 22, 2020 | 10:57 PM
Crash68's Avatar
Default LS2 wiring harness repair / replace
I have an LS2 in a 71 camaro and have experienced an intermittent issue where codes P0123 & P0223 related to the TB & Pedal... results in a rough idle, no connection of the pedal.
Have resolved the issue by pulling connections to inspect and replugging followed by clearing the codes... Problem is, it might come back so I'm wondering what would be the best way to perhaps address the wiring associated with these codes (TB/Pedal) without buying a new harness?
It's only happened twice, but it is something that may get worse and I would like to resolve with some confidence. I couldn't find an obvious wire cut/short.
Old Oct 23, 2020 | 12:41 AM
Often the mere act of unplugging and re-plugging connections will solve a problem or more by establishing a better contact, especially with a fresh application of dielectric grease.
Old Oct 23, 2020 | 05:36 AM
Michael Yount's Avatar
To G Atsma's point (and following up on your post in the other thread) -- I think I'd drive it a bit and see how it holds up before jumping on the new-harness bandwagon.
Old Oct 23, 2020 | 11:28 AM
Crash68's Avatar
Thanks. I hadn't thought about some dielectric grease to help the connections. I think I'll go back and do that and driver it.
