94 lt1 to 5.3 questions
What I want to do is:
car: 94 lt1 auto car, blown motor, can be had for at or under a grand.
engine: 5.3. Do I need to stick with a 3rd gen? or can I do a 4th gen 5.3? I plan to do a cam and turbo at a minimum, but would rather not replace the bottom end.
trans: stay auto. it wont be a daily or anything... just a fun weekend car that'll see the drag strip here and there. I guess I can go 4L60e or 4L80e? a th350/th400 would be fine with me too if that would work, overdrive is not a priority.
rear: not worried about this too much yet, but obviously the stock rear is going to have to go
ecu: since it being a non obd2 car I don't need to run through emissions. On initial look the Holley terminator x looks like it would be a good way to go.
I'm not too worried about the amount of work involved, I just want to common sense check myself here that this is a realistic idea and yes these ideas will work and want to make sure this is a good platform to work with car wise
from what I can gather so far I would need to swap out the k member for an ls based one(either factory ls1 car or aftermarket) and the trans crossmember would need to be made or modified. I assume a custom driveshaft would be in order for what ever trans/rear combo I go with. and the majority of threads I can find are more about the harness and wiring, which would be negated by the holley terminator. Can I or do I have to piggy back the stock ecu to run the stock gauges? Any other major roadblocks I'm not thinking of?
Sorry for the 100 questions, and I know the topic has been covered quite a bit on here but I did search and will continue to. one of the downfalls is theres SO MUCH info on ls1tech that it can be hard to sort through it all.
Thanks guys!
