Gen 5 L83 Cooling System
Old Oct 30, 2020 | 07:28 AM
sgo70's Avatar
Default Gen 5 L83 Cooling System
Okay here's another one, maybe I should do a build thread haha.
I'm planning out my plumbing and found this diagram for the LS, seems like it should work for the LT as well. My steam tube is at the water pump outlet so no big deal there but I noticed on the factory schematic they have a 5/8", I think, T coming off the lower rad hose. I figured I should add this and run it up to my pressure tank like the big line I added to the picture. Also I think line 15 should feed into the bottom of the overflow tank with an overflow tube coming out the top. Does this look right to you guys? Can you see any problems with this plan?
Thanks,
Sean
