Anyone using brake vacuum pumps
Old Nov 16, 2020 | 06:00 PM
Tramminc's Avatar
Default Anyone using brake vacuum pumps
I'm worried about them failing all of a sudden, and you only have the e-brake. there should be a way to tie in the engine vacuum as a backup. Possible using check valves from intake and pump.
Tramminc's Avatar
Old Nov 17, 2020 | 05:59 PM
stevieturbo's Avatar
Like with a simple tee piece ? Same way every OEM car does that uses an electric pump as well as engijne vacuum ?
Don't complicate something that's already extremely simple
Old Nov 17, 2020 | 07:33 PM
2knight's Avatar
Hydroboost if you want the best brakes possible.
