Oem piston and rod combo
Old Dec 1, 2020 | 09:08 AM
shitbox's Avatar
Default Oem piston and rod combo
Currently i have a bone stock pre-03 lq4 (press fit first gen rods) and it has metallic in the oil. Engine still runs great but i dont want to risk it shooting a rod through the block, so its time for a rebuild.
the car is boosted and makes 500hp, however, i want more. I want to upgrade to the floating rods (i have a set from a 5.3 sitting here) but i do not know if the oem lq4 pistons have the circlip groove in them. I want to know before i tear it apart.
does anybody know if the pre 03 pistons have the circlip groove cut out?
if they do will it be a direct swap? (aside from getting the rotating assembly balanced)
thanks!
Old Dec 1, 2020 | 12:46 PM
jarheadl34's Avatar
Why not just buy new flat top take out or replacement pistons and rings, they are cheap these days and will work with your gen 4 rods and give a boost in compression.
Jarhead
Old Dec 1, 2020 | 12:53 PM
shitbox's Avatar
Dont you want lower compression under boosted applications?
Old Dec 1, 2020 | 03:47 PM
LS1 TJ's Avatar
I would go out and buy new forged pistons and I or H beam rods since you may turn up the boost.
I've used Mahle and Diamond pistons along with Eagle and Scat H beam rods with good results.
Old Dec 1, 2020 | 04:03 PM
1FastBrick's Avatar
thanks!
No, they do not.
Old Dec 1, 2020 | 08:13 PM
AwesomeAuto's Avatar
Maybe in 1995 you did.
