2006 Tahoe Fuel Sending Unit
Old Jan 20, 2021 | 11:37 PM
ck_32's Avatar
Default 2006 Tahoe Fuel Sending Unit
Anyone know the ohm range for a 2006 Tahoe or from a 2015 Silverado? I’d assume they’d be the same range.
Im putting an LS from one in a 85 c10 and plan on using a 2015 dash cluster. Looking to buy the sending unit but need to find the ohm range.
Everything I’ve found I guys just jaw jacking or telling people where to go look but give no actual answers. Anyone actually know?
Old Jan 21, 2021 | 09:17 AM
ls1nova71's Avatar
Do you have the BCM out of the 2015 also? Don't think it will work without it since the 2015 cluster doesn't have a dedicated fuel gauge wire in it since it is on the CAN bus.
Old Jan 21, 2021 | 10:01 AM
ck_32's Avatar
2006 motor and PCM.
ive seen people make the 2015 cluster fully functional with as late as 2000 stock trucks with the original PCMs.
not sure how since none show their wiring or connections but I’ve seen tons of YouTube videos showing how it works when wiring it to the original chassis.
Old Jan 21, 2021 | 06:06 PM
ls1nova71's Avatar
Originally Posted by ck_32
2006 motor and PCM.
Sounds interesting. Do you have a link to any of those videos?
Old Jan 21, 2021 | 06:33 PM
ck_32's Avatar
