Gen 5 to Gen 1 wiring help please
Old Mar 6, 2021 | 01:07 PM
Jay Beckel's Avatar
Default Gen 5 to Gen 1 wiring help please
L99/6L80E into 69 camaro. Efi tank with 400lph walbro in tank pump, corvette filter/regulator. Will the engine run if we just power the pump? What work around a are necessary? Do we need to send any data to the ecm to make it happy?
Any help greatly appreciated!!
Old Mar 6, 2021 | 01:24 PM
LetsTurboSomething's Avatar
https://lt1swap.com/2010camaro.htm Pinout for the L99 harness in here. Everything in blue is needed/required everything in yellow can be taken out or left. Things not highlighted leave in too.
I can't answer from experience for you're setup as i haven't done one yet, but the pinout just shows a regular single fuel pump relay wire like every other chevy harness coming from pin 50.
Just hook it up to a relay like normal, should be all good. The ECM wire provides ground for the relay if I remember right.
Old Mar 11, 2021 | 05:26 PM
79LS1FOX's Avatar
delete
