New to the LS swaps
Additionally, my LS power steering pump pulley hit my Saginaw steering box. A one inch smaller pulley from a junk yard Chevy S-10 solved that problem but you will need a shorter serpentine belt with this fix.
Rick
Rick
That said, to the OP, you will need an LS1 intake and most likely the front accessories from one too to clear the hood, unless you plan on a big cowl induction hood. You will also need an F body oil pan and exhaust manifolds too. May need to swap out the K member which would make the engine a bolt in deal, but could probably be made to fit the V6 K member with some fab work, but why reinvent the wheel?
