Crank spacer
Old Apr 30, 2021 | 07:56 AM
jimmyg's Avatar
Default Crank spacer
So what's the deal . Info I have is it's needed for
4l80 with a flat flywheel . Other people are trying with out it but with a converter spacer . One guy destroyed his trans . Any body have reliable info ?
Old Apr 30, 2021 | 02:27 PM
The0nlyon3's Avatar
what engine and what is it from, same with the transmission. What’s it out of?
I had to use an adapter to run a th400 with my LS.. but that’s because the th400 converter needed it.
Old May 5, 2021 | 07:39 AM
jimmyg's Avatar
My buddy put a 4.8 with a t400
Supposedly used a dished flywheel with a little converter ring . Said no spacer needed with converter . Trans broke apart on dyno . Seems there is converters out there made for a dished( 4l60) flywheel ?
