1986 mustang tach wiring
Old May 3, 2021 | 08:49 AM
davidonmars's Avatar
Default 1986 mustang tach wiring
Trying to get my factory tach working in my 86 gt. Pin 10 on the gm ecu to the green yellow on the cluster, wire 12. I have changed my pulses from 2,3,4,6,8 in the tune high and low. I have added a 1k 1/4 watt pull up resistor and tried the same values. What am I doing wrong? The needle jumps slightly when you turn the key to run and then when you turn the key off.
