Harness and ECU Shop
Old May 7, 2021 | 05:34 PM
devildogmech's Avatar
Default Harness and ECU Shop
Hey all,
I'm finally at the point in my build that I need to find a shop to buy a harness (Mine was garbage) and get the VATS deleted.
What shops do you recommend? All the one's I had bookmarked over the years seem to have closed.
I'm half tempted to just get a Holly Stand alone system......
Thanks!
Will.
Old May 7, 2021 | 05:37 PM
Try Speartech or PSI.
Old May 7, 2021 | 06:29 PM
79LS1FOX's Avatar
I've always had good luck with BP Automotive 2 harnesses and 2 ECU's.
Old May 7, 2021 | 07:29 PM
LS1 TJ's Avatar
I've used Howell and Speartech with good success. Check on delivery earlier this year they were 12-14 weeks out.
Old May 8, 2021 | 08:22 AM
NCDEERE's Avatar
PSI for sure, nice harness.
Old May 8, 2021 | 04:34 PM
Project GatTagO's Avatar
Thanks!
Will.
That's not crazy talk. Let me know if you need assistance with tuning or just making sure you order the correct system. Summit probably has some in stock. Holley is backordered.
Andrew
Old May 9, 2021 | 11:05 PM
pdlightning's Avatar
Default Harness and ECM
Hey all,
Thanks!
Will.
Want them now?
Will, I have a new, unused reworked F body harness for the LS1 and a red/blue ECM (98-02) that has been reflashed and tested. All VAT and rear cats codes have been removed. The harness still is labeled for all sensors and ready to install. I have about $1300 invested. I also have unused MAF and DBC throttle body. If you need a NOS intake and both Corvette/Fbody fuel rails, I have those too. The Corvette fuel rail is also NOS . If you want these , make me an offer or email me @ 1miketerry@gmail.com
Old May 11, 2021 | 10:05 AM
Michael Yount's Avatar
PSI Conversions for my harness and ecu - first rate.
