Lm7 stand alone help!
Old May 20, 2021 | 08:14 PM
krazykawika's Avatar
Default Lm7 stand alone help!
Hey everyone. I need some help. I got a buggy with a 06 lm7 in it. The wiring was a mess so started cleaning up the harness. I’m down to the fuss box now and can’t figure it out. Every time I look anything up it brings me to this forum. I’ve gone through all of the past threads and tried tones of variations but not working. I know it’s gotta be something simple so I’m hoping the ones on here with MUCH more knowledge of this can help me out.
The main two are the fuel pump relay and ignition. If anyone can tell me what wire for what pins. I can find a different answer every time I look and have tried a few. Also the off/run/crank V and tac power (pink), what did you wire them up to? Thank you
Old May 20, 2021 | 10:12 PM
ls1nova71's Avatar
Pink wires are generally 12v ignition wires. LT1Swap.com will have all the info you need.
Old May 21, 2021 | 03:19 AM
I’ve gone to that site multiple times and those two wire can only be powered with key on power, not constant. I tried running those off the ignition switch but when I did it would cut the volts in half.
Old May 21, 2021 | 06:39 AM
dec010974's Avatar
Default Lm7 help
I tried to send my number thru private message but the board message said that you unable to receive messages. Private message me your number and I will help you answer any specific questions.
Old May 21, 2021 | 06:59 AM
dec010974, I don’t think it’ll let me. Says I need my account to be up for 30 days and have made 10 post. Heres an email you can send your number to. crapshoot13 at yahoo dot com
