Fuel Check valve location
Old Jul 7, 2021 | 09:45 PM
CutLS's Avatar
Default Fuel Check valve location
I'm installing a check valve into my fuel system. I'm running the Corvette regulated fuel filter. Should I install the check valve in the inlet port before the filter or after the filter on the main line? The only thing I can think of if it is after the filter, that should keep the main line pressurized, if the filter ever drained back for some reason.
Old Jul 8, 2021 | 07:11 AM
33willys's Avatar
Not sure I understand the need for a check valve. In my way of thinking what happens if there is a leaky injector? Wouldn't it be best not to have pressure on the system when not in use?
Old Jul 8, 2021 | 10:28 AM
CutLS's Avatar
All (most) systems have a check valve in the fuel pump but mine had just failed and would struggle to prime enough fuel pressure to start the vehicle. I'm replacing the pump and adding a check valve to keep the pressure.
