T56 Alternative
Old Jul 31, 2021 | 09:12 AM
Sway Tale's Avatar
I fold.
Denmah's car used a complete LOJ swap and the car came with a transmission.
On a technical point, a 240mm (9.5") diameter clutch will not handle as much torque under load compared to a larger diameter. LS engines come with 11" clutch disc as an OEM sports car application. I ran into an issue with this mostly at high speeds (110-165). I ended up having to get a custom flywheel made for $850+ so I could use universal 7.25" twin disc clutches. Clutch Masters was the only company that was willing to make me a flywheel and I didn't need to give them a 3D drawing. My cheap transmission swap adapter was $1250 and the flywheel that came with it is meant to use stock flywheel single disc clutches. The G-Force swap forces you to use a 240mm clutch disc.
Old Aug 2, 2021 | 10:43 AM
MuhThugga's Avatar
If my choices are between the Frontier 6 speed and an NV3500, I'm picking the Frontier's trans every time.
Old Aug 2, 2021 | 12:29 PM
64post's Avatar
Tkx ftw.
