oil leak after installing rear main-while parked
Old Jul 13, 2021 | 12:42 PM
Rustwater3's Avatar
Default oil leak after installing rear main-while parked
so my LS1 I noticed leaks about a 2" diameter puddle a week of oil of sitting. I haven't worked on it much in two months as I've been busy this summer with work. the rear main seal, pan gasket and rear cover were all replaced with fel pro products. I followed the guidelines on how to align the cover but I did not use the tool. Just the one that came with the kit on Amazon. What would cause it to leak when parked? I wouldnt think oil level is high enough to cover the crank seal.
Should I just bit e the bullet and pull the tranny to diagnose?
thanks
tony
Old Jul 13, 2021 | 01:25 PM
Jimbo1367's Avatar
What kit? Is this a auto or stick vehicle?
Old Jul 13, 2021 | 03:07 PM
LS BRAVADA's Avatar
I thought mine was leaking at the seal. Upon further investigation it was leaking and running down the pan rail and dripping off near the seal due to me forgetting to dab some silicone in the 4 corners where the block meets the front and rear covers…
Old Jul 13, 2021 | 04:20 PM
RedXray's Avatar
Yes without the RTV in the corners it will mimic a rear seal leak.
Did you inspect the seal and install with the "this side out" letters out?
Old Jul 13, 2021 | 06:34 PM
Rustwater3's Avatar
I did double check the rear seal outside notation. Also did dab on some rtv at the corners. It's a t56 tranny, all going in a 65 f100
Old Jul 14, 2021 | 04:58 AM
Jimbo1367's Avatar
I thought I seen something about the flywheel to crank bolts Can leak oil if sealer isn’t applied as the holes go into the engine. Not sure if that’s early years or not
Old Jul 14, 2021 | 07:16 AM
Rustwater3's Avatar
Engines out of a 2004 gto if that makes any difference.
Old Jul 14, 2021 | 09:10 AM
Jimbo1367's Avatar
I’d pull out a bolt to see if it’s wet on the end. When I seen this issue, I was surprised as I never seen it on here be talked about before.
please keep the forum informed once you find the culprit
Old Jul 14, 2021 | 02:07 PM
BadgeZ28's Avatar
I second checking the flexplate or flywheel bolts as a source.
Old Jul 16, 2021 | 03:35 PM
Rustwater3's Avatar
I pulled the tranny today. I think I found the issue. One of the rear long oil pan 10mm bolts is leaking through the threads. Can I just put sealant on it? It's weird that it's leaking. I did not find any oil around the cover gasket oil crankshaft gasket. Oh, and I remember now putting extra rtv after I mated the two together. There's also rtv between the pan and rear cover. There was no sealant on the flywheel bolts and they were dry.
Old Jul 16, 2021 | 09:43 PM
tblentrprz's Avatar
The rear 6mm long bolts (10mm head) go into blind holes in the rear main cover. If you're using felrpo pan gasket, the rubber is too thick and hard and will split at the corners when torqued and leak. I recommend GM pan gaskets, no problems. Did you replace the rear cover gasket? It fails like the oil pan gasket when the seal separates from the alum frame.
Old Jul 17, 2021 | 11:34 AM
Rustwater3's Avatar
I did use felpro pan gasket. I realized I installed the pan gasket before the cover gasket too. Maybe that failed?
Old Jul 18, 2021 | 05:43 PM
Rustwater3's Avatar
I replaced the pan seal today and found the issue. When I installed the rear cover, the pan was in pace first. I'm sure I tore it doing it this way
Old Jul 19, 2021 | 09:07 AM
Jimbo1367's Avatar
I’m glad you found a definite answer.
Old Oct 17, 2021 | 04:44 AM
Hugo_56's Avatar
I have a 2000 LS1 that is leaking oil and my winter project is to find the source. I suspect it is coming from the oil pan but unsure. Suggestions on where to start?
Old Oct 17, 2021 | 10:39 AM
Clean whole area, then look for seepage.
