6.0 swap
The wiring will be the same as long as the intake is the same or you use the intake you are currently running on the 5.3
You may have to swap the oil pressure sensor but again it's a direct swap.
All 4.8 5.3 5.7 6.0 6.2 engines will bolt up to the 4l60e with the correct flywheel. The 99-00 LQ4 had a longer crankshaft than the 01-07
