Need help
Old Sep 6, 2021 | 12:37 PM
not2oldchevy's Avatar
Default Need help
53 chevy truck 5.3 . Have used 3 fuel pressure regs.Cannot get over 50 lbs pressure rev it up and drops into the 40s .Just put the third one on 50lbs unhook the vacuum port goes to 58 and stays. Anyone know the problem and will it hurt to plug the vacuum line and run it? thanks
Old Sep 6, 2021 | 01:57 PM
Which pump? What's the pressure BEFORE the regulator?
Old Sep 6, 2021 | 03:27 PM
ls1nova71's Avatar
Sounds like you have a flex fuel engine, at which that would be about right.
Old Sep 6, 2021 | 05:23 PM
pdxmotorhead's Avatar
+1 my L59 intake and injection runs between 45 and 48 lbs most of the time.. I was using my stock YJ pump and upgraded to a higher pressure and the rail stays right at the same pressure. But it peaks about 4 lbs higher at WOT..
