LS Swap
Old Sep 10, 2021 | 06:27 PM
camcont's Avatar
Default LS Swap
You
doing an LS swap and using my existing 700R4 transmission by using a adapter plate. only the tapered end of my bell housing dowels stick out now. is this OK since I have to bolt up 6 bolts from the transmission to the engine?
Old Sep 12, 2021 | 02:28 AM
Kawboom's Avatar
The LS engines share the same bellhousing pattern as the big block and small block Chevy going back to the late 50s. I dont think you need any adapter plate.
