Dirty Dingo Motor Mounts
For example: if you needed to pull the transmission tailshaft over to more easily locate the bolt holes that go from the crossmember into the transmission mount.
Will the dingo mounts allow that kind of movement or or they just restricted to slide to the front and back?
I had very tight hood and power steering clearance. I just used washers under the motor mounts (between frame and lower mount) to adjust left right up and down as needed. It was easier than I thought to shim the motor with the motor trans installed.
