Ls sway
Old Oct 5, 2021 | 12:07 PM
Mapplin's Avatar
Default Ls sway
I’m new at this so bare with me I have a 1984 z28 I’m ls swapping and I’ve ran into a problem the center link hits the oil pan but I do have a Manuel gearbox and I used the Holley oil pan and I have solid Moro so mount both on the frame and engine can anybody help me with any advice on fixing the problem thanks
Old Oct 5, 2021 | 12:09 PM
jasons69chevelle's Avatar
What Holley oil pan. What engine mounts are using.
Old Oct 5, 2021 | 12:41 PM
Mapplin's Avatar
Holley 302-2 and Moroso 62510 and 62610
Old Oct 5, 2021 | 01:21 PM
Mapplin's Avatar
Sorry but it’s not the 302-2 it’s the 301-1 that may be the problem but I think the sump is longer on the 302-2 and it may hit the k frame
Old Oct 5, 2021 | 03:34 PM
1964SS's Avatar
The 302-2 is the one listed as the correct pan for your swap. It would give you the extra clearance at the front you need. If you are set on using the pan you have then you could try shim plates under the motor mounts but this is going to raise the motor and mess with your driveline angles which would then have to be corrected as well.
Old Oct 5, 2021 | 03:39 PM
Mapplin's Avatar
Thank you I appreciate it
