Gen 5 with a carb........
I am looking at getting a 2018 5.3 block for a 427 build. Have it sleeved and install a rotating assembly.
Cam will probably be the biggest problem because of the DI on the heads and intake.
I figure I am more or less pissing in the wind for now. Unless someone can point me in the right direction.
In a swap or conversion, I'm still not convinced that a Gen5 motor really is an upgrade over a Gen4 motor. I think more aftermarket support needs to be out there for controlling the DI and VVT before it will be more of a benefit.
a Gen V L83 will give a run to a LS3
I am gathering information right now as I have not decided what direction I will be going.
I haven’t messed with anything Gen 5 yet. And may not because of the cost. May just say screw it and get a gen 6 454 and build one of those with a solid roller cam.
https://www.chevrolet.com/performanc...s/ls/ls427-570
*Edit: I guess hypothetically if you were going to sleeve an L33 and build a 427 and then sleeve an L83 and build a 427 and use the stock heads on both, the L83 heads are likely better....if for some reason you were going to sleeve a block, buy a stroker kit, and then use the stock cylinder heads.
If you really for some reason want a carb, which doesn't make a lot of sense when there is completely self learning efi that can be setup with a basic handheld, then you're better off with an earlier LS where you don't have to work backward against DI.
My current block is a Gen 3 5.3 that is bored to 5.7 specs. I can stroke it to 383.
My second current block is a 351 Cleveland that had to have a sleeve put in it.
It will hopefully be ready for me to get Saturday providing I get the deposit I am expecting.
I expect to be picking that up along with the crankshaft for it.
