Noisy valve train
Old Nov 18, 2021 | 04:48 PM
LS BRAVADA's Avatar
Default Noisy valve train
Been dealing with a noisy valve train for some time and finally getting around to wanting to try to get it quieter. My build is a 2009 L76 with LS3 take out cam shaft, 12610046 head gaskets, 12499225 lifters and 7.400” (measured with calipers) stock pushrods, stock CTS-V exhaust manifolds, non milled heads AFAIK. All DOD/AFM was intact before I did the LS3 cam swap. Car runs like a scalded dog just noisy. I ordered the pushrod checker tool and should be here tomorrow. Anyone have any insite on this, what’s recommended preload on the 12499225 lifters. Any help is appreciated…
Old Nov 22, 2021 | 03:23 AM
Jimbo1367's Avatar
What lifters are these? I can’t imagine everybody has lifter P/Ns ingrained to their memory like the 18436572 firing order of many old v8s
Old Nov 22, 2021 | 02:26 PM
LS BRAVADA's Avatar
Originally Posted by jimbo1367
what lifters are these? I can’t imagine everybody has lifter p/ns ingrained to their memory like the 18436572 firing order of many old v8s
gm ls7
Old Nov 22, 2021 | 02:32 PM
SAPPER's Avatar
Are these actual GM LS7 lifters or LS7 "Style" lifters? The style is the keyword. Some aftermarket lifters require more preload to keep from chattering.
Or you may need to check pushrod length to get proper preload.
Old Nov 22, 2021 | 03:28 PM
I bet he has bogus LS7 lifters. GM used the same pushrods for all non-LS7 engines, including after they started using LS7 lifters in all other engines.
IF this is a stock LS engine, with genuine LS7 lifters, stock 7.400 (nominal) pushrods should work noiselessly.
Old Nov 22, 2021 | 04:18 PM
Jimbo1367's Avatar
I’m so sick and tired of counterfeit parts. Why can’t we get what we pay for. If they are clones, they should have to put a legal disclaimer.
Old Nov 22, 2021 | 06:24 PM
SAPPER's Avatar
I am sold on GM lifters from CamMotion. Bobby hooked me up with TRUE GM lifters. Even destroyed my price I get at work at the dealer for the same p/n.
Old Nov 22, 2021 | 08:25 PM
LS BRAVADA's Avatar
I get ONE turn of preload after zero lash with the stock 7.400” pushrod. From what I’ve been reading that is not enough for LS7 lifters. I ordered 7.425 PR to see if they will quiet down some. Will report back with results…
Old Nov 22, 2021 | 10:20 PM
RedXray's Avatar
If you didn't pay around $375+ for the "LS7" lifters they're probably the bulk Delphi $120ish lifters. I had a set of the bulk lifters on a 228/230 cam and they had the annoying sewing machine noise. Upgraded to a bigger camshaft with Morel 6504 lifters and the valvetrain is almost silent vs the bulk LS7 setup.
Old Nov 22, 2021 | 10:42 PM
Tyler Dietzenbach's Avatar
Highly recommend the Johnson drop ins. Especially over the LS7s. Real or fake. .
Old Nov 23, 2021 | 09:06 AM
Jimbo1367's Avatar
Since GM lifters are a crap-shoot, I went with both style (LS7s & replacement) from Summit Racing. Plus I’ll keep my 30k mile OEM lifters for a back up.
Old Nov 23, 2021 | 09:43 AM
SAPPER's Avatar
Or find yourself an old 87+ gen 1 roller motor and take lifters from it. The original Delphis never died. LOL I have 2 engines with the originals in them. They'll last forever.
Old Nov 23, 2021 | 12:19 PM
ryeguy2006a's Avatar
Keep me posted, as I went through this same exercise a few months ago. It was determined that I needed 7.425" push rods, but after swapping them out there was no change in the sewing machine noise. It's interesting that you are running stock manifolds because I was thinking that it was possible my headers which I've used on multiple engines in the same vehicle were to blame. Had the same noise with an LS1 and now with my 6.2.
Old Nov 23, 2021 | 02:08 PM
Jimbo1367's Avatar
I e heard that headers can cause this noise but I don’t have any first hand knowledge of this.
Old Nov 23, 2021 | 04:42 PM
LS BRAVADA's Avatar
Also forgot I installed PAC-1218 valve springs, if it makes any difference…
Old Nov 23, 2021 | 06:42 PM
69-chvl's Avatar
Although I only have about 2hrs of idle time on my 6.2 L94, it is very quiet with the same lifters, STG2 BTR cam and BTR dual springs. I am running 7.425 pushrods which was exactly the midpoint of travel for the lifters (which I measured with a dial indicator). Hopefully it stays quiet.
Old Nov 26, 2021 | 01:42 PM
LS BRAVADA's Avatar
Default Update
UPDATE:
I received the 7.425” pushrods today and installed them. The valve train is very quiet now. All I hear are the injectors snapping until I put my engine cover on and that noise almost completely goes away. Now off to the tuner to get this trans dialed in. thanks for all the help…
