Aftermarket Temp Gauge Question
Both heads have the same hole in them. But somewhere (I cant find the reference now) I remember reading the driver front port
works better due to proximity to the water pump and the steam port in the head. LOL getting old..
I have a two coolant gauges on mine - one in the dash and one under the hood. I mounted both sensors in the side tank of the radiator just below where the upper hose (hot coolant leaving the engine) connects. They read within a few degrees of the temp the ECU sensor (U.S. driver's front head) spits out on my hand held.
If it were mine, I'd want that gauge sender relocated. My motor very similar to yours -- crate LS3 circa 2015.
