Need help with 05-13 corvette pedal
Old Mar 31, 2022 | 11:19 AM
yellowGT's Avatar
Default Need help with 05-13 corvette pedal
I wanna use o5-13 corvette pedal on 04 6.0 but how do I go about doing that? I’ve swapped tac box and finally got something outta the original pedal but can’t get anything outta the corvette pedal? I’ve tried researching wiring but no luck with any configuration.
Old Mar 31, 2022 | 11:39 AM
theunderlord's Avatar
What PCM are you using, and what car is it going into?
Old Mar 31, 2022 | 11:48 AM
yellowGT's Avatar
its a swap going into a old truck but the donor is a 6.0 from a Yukon Denali. Basically using everything except corvette intake and tb. X-link was installed too to communicate with tb and works great but like I said with original pedal and not with the corvette pedal. Pcm is from the donor as well.
