iat sensor problem
Old Jul 29, 2022 | 03:52 PM
Maus's Avatar
Smile iat sensor problem
Hello , I´am new here
have a engine from gmc yukon 2001 , 5.3 L , swapt into old truck , starts right up , idle okay but when I hit the gas it runs not good , have ecm flasht with hp tuners , when I look into HP tuners vcm scanner I see a problem with my mafs sensor , it says minus 39 degrees , but it is around 22 degrees when start up , the maf sensor was gone but have buy one from that year , but connector do not fit correctly , have wired an 2 wire iat sensor but still the wrong temperture , what do I wrong , maybe wrong wire used , thanks Maus
Old Aug 1, 2022 | 12:07 PM
The0nlyon3's Avatar
wow I got a migraine trying to read this…
if you have a 5.3 from a 2001 Yukon I believe your MAF has the IAT sensor built into it…
the plug should be the same for all MAFS that have the IAT built in.
Are you using an AC Delco MAF? IAT?
check your wiring, make sure nothing is cut or grounding out.
did you buy a stand alone harness or did you convert your stock harness to stand alone?
Old Aug 1, 2022 | 12:44 PM
Maus's Avatar
Smile
sorry for the text , I from the netherlands , think we speaking and writing a bit difference , thanks for the info go check it again ,the maf is from ultra power
Old Aug 1, 2022 | 04:40 PM
The0nlyon3's Avatar
now I feel like a jerk. My apologies! I have had NO luck with non factory sensors
Old Aug 2, 2022 | 08:02 AM
bobcratch's Avatar
its probably a wiring issue if the temperature is saturating low
Old Aug 2, 2022 | 01:12 PM
Pulse_GTO's Avatar
Are you using a separate 2 wire IAT sensor? Try swapping the wires and see if you get an accurate temperature reading.
Old Aug 2, 2022 | 03:54 PM
78TranzAm's Avatar
What harness are you using? Is it set up for a 5 pin MAF sensor or does it have a 3 pin plug with an extra 2 plug pin next to it?
