Injector issue
Old Oct 16, 2022 | 10:42 AM
signguy62's Avatar
Default Injector issue
Help!
4.3l to 5.3l swap was pretty much done and running fine.
Decided to swap to factory e-fans. Found a 34" radiator and dual factory e-fans on Marketplace. Ended up buying a swap harness for the fans from BP Automotive.
Got everything hooked up, filled the radiator and went to fire the engine up to circulate the coolant and it wouldn't fire.
Turns out the injectors are firing continuously with the key on and flooding the cylinders with gas.
The wiring for the e-fans is pretty straight forward except for the 2 pins you have to add to the ECU.
How the hell are the injectors getting continuous voltage with the key in the on position?
Old Oct 16, 2022 | 01:50 PM
rpturbo's Avatar
They ground pulse, so it sounds like you have grounded that circuit or damaged to ecm.
