IAT sensor position?
Old Oct 18, 2022 | 08:58 PM
Poncho72's Avatar
Default IAT sensor position?
Finally got my 98 F-body LS1/T56 dropped in my 72 Firebird, and need opinions/guidance on if it matters that i mount the IAT sensor before or after the MAF. It was originally before the MAF, but will take more fabrication to mount it as factory. I'll also need a wiring extension if it has to be mounted before. i am using a PSI harness and a aftermarket cold air intake routed the left fender. Thanks.
Old Oct 19, 2022 | 07:19 AM
Aston Tibs's Avatar
You can easily extend the harness for the IAT to put it in front of the MAF or wherever you want. WIth that said, I have mine after the MAF and it works fine.
Old Oct 20, 2022 | 12:20 AM
Poncho72's Avatar
Thanks
