LS3 engine swap evap
Old Oct 19, 2022 | 06:54 PM
alexsp's Avatar
Default LS3 engine swap evap
Hi everyone!
New to the group and first engine swap I'm getting into.
I would appreciate all your help and thank you in advance for that. Chevy enthusiast but not very familiar doing this swaps and trying to get it right. I'm learning as I go. I also used to count with some help when I started but now I'm on my own. The engine I'm using is a LS3 crate engine. I have some things figured out but the one is giving me some headaches is how to run properly the evap system (or deleted) and vent the fuel tank. Which lines/hoses I should route from the tank to the engine, ports to plug... I read some info out there but everything at this point seems a little confusing. Due the donor vehicle was originally an old diesel there is not charcoal canister or anything I can use as example. If anyone have a good diagram, knows a shop manual that it would help with the task or could point me in that right direction it would be great.
Thank you again.
Alex.
Old Oct 19, 2022 | 08:02 PM
LS1 TJ's Avatar
The vent for the fuel tank can be as simple as a vented gas cap. The LS3 will only need one pressure fuel line up to the fuel rail. I like to use -6 SS line. Along with a FFR (fuel pressure regulator) near the tank. I like to use the C5 2004 and earlier FFR. I never used a EVAP system on my LS swaps.
Good luck with your swap.
Old Oct 21, 2022 | 03:39 PM
alexsp's Avatar
Thank you so much for your help.
I think I use the same fuel line as yours up to the fuel filter regulator (I used this one PF5493 if I'm not mistaken). Then a small section of regular fuel injection hose to the tank. To Vent the fuel tank I was thinking of using this: GM20995472.
