DBW Pedal choice
Old Jan 18, 2023 | 08:08 AM
dw456post's Avatar
Default DBW Pedal choice
Which pedal assy fits best in a 2000 Camaro? Corvette---CTSV---or Truck pedal ? Thanks
Old Jan 18, 2023 | 08:46 AM
aknovaman's Avatar
It depends on what ECU you are using cause they are not all electrical compatible.
Old Jan 18, 2023 | 10:51 AM
dw456post's Avatar
ECU is 2012 E38, serv#12633238, part#12647990
Old Jan 18, 2023 | 10:54 AM
aknovaman's Avatar
get a silverafo pedal, cut off 90% and bolt on the factory metal pedal. that's the easiest solution I have found, if you are running a silverado file. I have seen many people make this way to complex.
